I have this schematic for a 27mhz radio transmitter it just sends a signal that is then received and turns an led on when the button is pushed down. what I want to know is how do I change this circuit using the simplest method to change how much power is outputted. for example if I wanted more transmitting power what do I need to change or add and if I want less power what do I change or remove.
