changing the output on a variable power supply
Discussion in 'The Projects Forum' started by AznGothic, Apr 20, 2016.
  1. AznGothic
    Feb 17, 2008
    11
    I have a variable power supply that puts out 19.5VDC when the potentiometer is one way and about 27.3VDC turned the other way. I need a power supply that is 14.4-14.6VDC. Can I simply change the potentiometer on the variable power supply to a different value potentiometer so that I can get 14.4VDC? Or is there more to it than just that? The power supply label says it's 27A in case that's relevant.
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    Easy to modify, can you get model number or circuit diagram, otherwise need to open it up take pictures of the inside, note any regulators ic's etc...
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Can't say without a schematic.
  4. arunpradh
    Member
    Dec 11, 2013
    43
    easily modify using variable voltage regulators. refer circuits of Lm317.
  5. AznGothic
    Feb 17, 2008
    11
    I do not have a schematic and it doesn't have any consumer type labels on it. It is from the military and they usually put their own labels in things. It also doesn't have a cover though so I can snap some pics and upload them. I honestly want a power supply that puts out 50-100A but seeing how those are pretty expensive I figured I would put this one to use if it can be modified. Would I lose any of the amperage output after modification?
  6. Dodgydave
    Jun 22, 2012
    5,142
    768
    Not usually, if its a regulator or transistor output, current is set separately.
  7. AznGothic
    Feb 17, 2008
    11
    Ok. I'll be heading to my shop in a minute. Takes about 20mins to get there. I'll snap pics and upload them as soon as I'm there. Thank you for the help :)
    Dodgydave likes this.
  8. Dodgydave
    Jun 22, 2012
    5,142
    768
    Take pictures of the components side and track side, any wiring to the pots,more pictures means better answers...
