Changing the frequency
Discussion in 'General Electronics Chat' started by johnny23, Jun 15, 2014.
  1. johnny23
    Jun 15, 2014
    If you want to make a circuit that receives a triangle wave with a known frequency and changes it while maintaining the amplitude, do you have to transform into DC and then generate a new triangle wave (which is not easy, i guess) or are there easier ways?
  2. crutschow
    Mar 14, 2008
    13,519
    3,386
    Can't think of an easier way. You could use a positive and negative peak detector to set the positive and negative peak values for the new frequency. Is this from one fixed frequency to another fixed frequency or are the frequencies variable?
    johnny23 likes this.
  3. johnny23
    Jun 15, 2014
    Thanks for answering
    Yes. A fixed known frequency will enter the circuit, and I want to multiply that frequency by 4, without changing the amplitude
  4. crutschow
    Mar 14, 2008
    13,519
    3,386
    So this fixed frequency will not vary in frequency?
  5. johnny23
    Jun 15, 2014
    for example, if i know the input is always going to be a triangle wave with 50k Hz and amplitude A, i want to make a circuit in which the output is always a triangle wave with 200k Hz and amplitude A
  6. crutschow
    Mar 14, 2008
    13,519
    3,386
    Does the output frequency need to be exactly 4 times the input frequency?
    What's the purpose of this output?
  7. johnny23
    Jun 15, 2014
    Not exactly, but with something like 90% precision.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    This is easy. The triangle already has 4 distinct time points that can be references to product a new frequency. You have the peak max, min and two zero crossings ( use a capacitor if needed ) now you can use these 4 points to generate a signal of twice the frequency. Do this twice, and you have 4x frequency.
  9. MrChips
    Oct 2, 2009
    12,652
    3,461
    What is your application? Is this homework?
