Changing Speeds on 8" Drill Press
Discussion in 'Off-Topic' started by nDever, Feb 19, 2015.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey Guys,
    I'm back with my drill press from Harbor Freight. If you posted on my problem thread (http://forum.allaboutcircuits.com/threads/pcb-drilling-solutions.105969/), then you know that I bought this primarily for PCB hole drilling. It works great, and it was a perfect solution; I've made a few boards already!
    My problem now is that I need to switch to a higher speed. The manual said that I needed to change the position of the drive belt, but it's significantly tight and I don't want to break it. Does anyone who has this drill know what the problem is?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    There should be a way to loosen the motor mounting rods and slide the motor to the front. It looks like there may be a lock on the RH side. From the design, there may be a lock on both sides. The belt does not have to be real tight. You also remove from the large pulley first. I went to "link belt" for my drill press (e.g.,http://www.zoro.com/i/G3722311/?utm...hopping_Feed&gclid=COjuuu6B78MCFYk8gQodFqQAig). It runs much smoother.
    John
  3. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    It looks almost identical to mine, there is a tensioner on the same side as the lid latch that removes the tension on the belt for changing.
    You may want to look at a DC T.M. motor and simple controller and get rid of the belt nuisance, especially for light work such as electronics.
    Max.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I switched to a 3φ motor and never regretted it. The DC or 3 phase work about the same in this application, but the 3 phase motor may be cheaper. Mine was a slightly bigger drill press, and the bigger 3 phase motor was quite inexpensive. Both will give soft start. The 3 phase will also give a little "overspeed;" whereas, there is nothing faster than 100% for the DC motor.
    John
  5. nDever
    Jan 13, 2011
    154
    Thanks guys, I finally figured it out.
  6. #12
    Nov 30, 2010
    16,663
    7,306
    Other options that might not be practical or even possible:
    1) Increase the size of the pulley on the motor shaft
    2) Buy a faster motor.
  7. Nykolas
    Member
    Aug 27, 2013
    92
    31
    This is what I use: http://www.harborfreight.com/vibration-free-link-belt-43771.html on a similar Craftsman press. I am waiting for a used 90VDC motor to replace the AC unit and have complete electronic speed control. My press did not come with a light. I installed a 10W LED between the drill shaft and the main post. Electronics inside the hollow casting. E
