Changing out a Capacitor
Discussion in 'General Electronics Chat' started by CompEng, Apr 8, 2009.
  1. CompEng
    Apr 8, 2009
    I have two caps. Both have the same specs, but the diameter and length of each are different. Is there any problem in interchanging them? The orignial cap was fatter and shorter but for some reason the new type has a smaller diameter and is a little longer in length. They are electrolic and like I said all the voltages, μF's and temps are all the same. The only diff is the size (length and diameter)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That depends on the application. If the capacitors are used in high frequency circuits, like output filters for a SMPS, then the ESR rating becomes the defining parameter. In that case, a capacitor with a higher ESR can't be used as a replacement.
    Otherwise, if it fits, it should work.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    What is a ESR rating? Tried to look it up on wikipedia with no luck.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
