Changing LED color with button press
Discussion in 'The Projects Forum' started by caram, Sep 16, 2013.
  1. caram
    Sep 16, 2013
    Hey everyone,
    I'm new to the world of electronics and wanted to ask you how do I go about changing LED color with a push of button or switch..
    example: lets say we have 5 LEDs in a line and they all the switch to the same color once I push the button and then to another when I push it again, etc. A fading transition between colors would also be a nice thing to have, but not necessary.
    I have RGB LEDs as well as different colored ones.
    Is there a simple schematic or tutorial that I can use as reference? I've looked everywhere but I can't seem to find one that explains how to do this.
    I can use a breadboard and possibly an Arduino.
    Any help would be appreciated! :)
  2. adam555
    Aug 17, 2013
    858
    39
    Hi, with arduino is very simple: you connect each color anode of the LEDs to a different pin, the cathode to ground (through a resistor), and an additional pin for the switch. Then program it to change colors as the switch is pulsed.
    Without arduino you can do with a monostable flip-flop, for example:
  3. Bernard
    Aug 7, 2008
    4,240
    414
    Try using a 4017 0r 4022 counter. connect desired number of outputs with RC coupling to emitter followers to drive the LEDs. Are LEDs common anode 0r common cathode?
