changing inverter output
Discussion in 'General Electronics Chat' started by Antish, Jun 24, 2009.
  1. Antish
    Jun 13, 2009
    5
    hi
    what maters to change the output? how can i change the out put volt as i want?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome to AAC. We ask you to always start a new thread for each question. The one you posted in - http://forum.allaboutcircuits.com/showthread.php?t=9909 - is over a year old.
    Inverters use a step up transformer for their output. Changing the turns ratio alters the output voltage.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    If the inverter does not have voltage regulation then changing the battery voltage also changes the output voltage.
    Frequently the battery voltage drops (and the output voltage of the inverter drops) when the inverter is loaded if it does not have voltage regulation.
