Changing Files
Discussion in 'Computing and Networks' started by Sparky49, Sep 11, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi everyone,
    I've tried to download some footprints for Eagle from Farnell, however when I open the file, my computer says it is a screensaver file, whereas it is supposed to be a script - .scr.
    What can I do to fix this?
    Sparky
  2. bretm
    Member
    Feb 6, 2012
    152
    24
    If you're using Windows 7, right-click on it, choose "Open With" and then choose either Eagle or "Choose default program" if you just want to be able to double-click them and have them always open in Eagle.
    Sparky49 likes this.
  3. Sparky49
    Jul 16, 2011
    835
    417
    I can't do that. :(
  4. sbixby
    May 8, 2010
    57
    10
    There's another way to associate a program with a file.
    In Windows Explorer, right click on the file, click "Properties". On the "General" tab, there's a line saying "Opens with:...." and a button. Click the "Change" button.
    Now, in the resulting dialog box, navigate to Eagle, one way or another. First, click the little arrow at the end of the "Other Programs" line and see if Eagle is there - since it didn't show up for you in "Open with", it might not be here either.
    If not, click the "browse" button and navigate to Eagle's EXE file under "Program Files" or "Program Files (x86)" structure.
    Once you've selected a program, it becomes the default program opened when you double-click on a file.
  5. sbixby
    May 8, 2010
    57
    10
    Oh, btw, if you don't want to associate a file with a program, it's perfectly OK to just open Eagle first, then File -> Open, navigate to your file location and click into it there.
    I made the assumption you wanted to always open Eagle when clicking on SCR files but that isn't necessary by any means.
