I 'm working on a device which according to the below diagram, has a solar panel witch gives at most 10v voltage and 30mA current (average 9v and 20mA) and also it has a 6v lead acid dry battery with 3.2Ah capacity. The system (main circuit) works with 3.3v and draws in standby 1mA and depending on the task, 6 mA or 20mA or 100mA or 300mA, say 8 times a day.
I wanna add some super capacitors to the device to store energy when the battery is full or to reduce the number of charging cycles (for lengthening the life of battery) and probably to remove the battery and also I wanna use a switching converter for reducing the power loss in the device instead of linear voltage regulator. Now my questions are: 1. Is the future circuit diagram is correct? Can 3 super cap.s be matched with battery and solar cells voltage in aspect of difference peak voltage that they will have? 2. Is the capacitance of the super-caps is enough to supply enough power to the system or we need the battery as well? Can we use a different, smaller, batteries from different type? 3. Do you have any recommendation for a suitable IC as DC/DC buck converter? If you have any recommendation or comment regarding the this problem, please share it. Thanks.
