I got a kit where you build a 12vdc Variable PS but after building it is reading 19.8vdc. The kit did not a have the schematic and I need to change it to a Dual PS. one fixed and one variable. I am running a small variable motor and a fixed 6-12vdc for a counter. the project is a Guitar Pick-up winder.
The PS is reading 19.8vdc so I want to slit the voltage by adding a second circuit.
I tried setting up second voltage just before the variable pot but when I turn up the pot the voltage on the second lead goes down.
