changing 12 volts gel cell battery using solar panel
Discussion in 'General Electronics Chat' started by mrel, May 27, 2016.
  1. mrel
    Thread Starter Active Member
    Jan 20, 2009
    98
    Hello
    when changing 12 volts gel cell battery using solar cell is it better to have higher voltage or higher current to full the charge the battery.
    mrel
  2. Alec_t
    Sep 17, 2013
    5,952
    1,129
    It's better to use a dedicated charge controller IC so that the battery can be charged according to the manufacturer's recommendations.
    Suggested reading.
    nsaspook likes this.
  3. bwilliams60
    Nov 18, 2012
    734
    94
    Gel cell batteries are sensitive to charging voltages. High voltage will damage the battery. Refer to the manufacturers specs for the proper voltage. As for current, low current slow charge will always be the best no matter what kind of battery.
  4. nsaspook
    Aug 27, 2009
    3,006
    2,348
    It's heat that's the main cause for battery degradation and gel cells are sensitive due to their physical construction. For systems designed with good thermal management (passive as with large traction batteries or active as with many Electric vehicles liquid cooled BMS systems) the rate of recharge has little impact on battery life as simply charging at any rate itself degrades the battery with elevated temperature of the chemistry increasing capacity loss.
    https://avt.inl.gov/sites/default/files/pdf/vehiclebatteries/FastChargeEffects.pdf
