Hi Andy,
Yes read that link OK.
Do you have a bread board that you could build just the SMPS/555 part of W's circuit.
You could then use a resistive dummy load to test it to approx 150mA and then scope the waveform across the load to determine the voltage swing.
In series with dummy load add a 1N4001 diode, this will give a very rough guide in the way the final LED array will perform.
I don't see why you want to give me the manufacturer of the 555.?
The problem is not with the 555 it is with the very poor regulation of the design of the 555 switcher for driving the LED's in your project.
The LTSpice simulation shows that the LED current would be much higher than the specified LED limit.
hi Andy,
This is one option, change the LED array layout to suit the high Vout, this will lower the LED current.
You may need to adjust the {rs} resistor value a little to optimise the current and brightness of the LED's [ note the right side LED chain has a 240R resistor.]
The FET can be any N MOSFET with a Id current rating over say 1 or 2 amps.
Let me know the FET type you have and I will check the spec.
Excellent Eric, the FET I need to purchase yet, Yes I will forward the spec.
So we have an output of 36 volts, 10.9mA per led, Yes I note the RS value for adjustment of led and the last one is 240 ohms.
Any chance of forwarding to me this LTSpice test of this circuit? as I like to learn? just upload to a cloud Eg: google drive, or attachment.
Andy
Place the TLC555.asy file in the LTspice\lib\sym folder.
Place the TLC555.asc files in the LTspice\MyWork\555 folder
[you will have to create the MyWork\555 folders or use folder names of your own choice]
Place the TLC555_mod.txt file in the LTspice\MyWork\555 folder
Place the timers.lib in the LTspice\lib folder.
You should now be able to run LEDsmsp1.asc
I would suggest you consider creating a folder in the LTSpice main folder for all your work [mine is MyWork] also sub folders under MyWork, use sub folder names that are easy to recall
Quick question I buy 5 cheap LDR's from China, what I thought where 10 M ohms, they are all over the place in ohms.
1./ Light resistance 0.9K Dark resistance 6.5K
2./ Light resistance 1.4K Dark resistance 12.7K
3./ Light resistance 0.8K Dark resistance 6.4K
4./ Light resistance 0.9K Dark resistance 6.5K
5./ Light resistance 0.75K Dark resistance 9.7K
Or should cut my losses and go a buy a 10M ohm LDR?
Or I need to add more resistor to the 555 timer circuit?
hi A45,
I would suggest using the Chinese LDR's, just change the series resistor.
The biggest change looks like LDR #2 or #5, I will run them in simulation and post what I find suitable. OK
E
