Change this circuit to 12 volts
ericgibbs
Joined Jan 29, 2010
18,849
I think the 10mm for the LDR applies to its light sensitive area.???
Do you have the LDR on the bench.? or have you ordered one?
ericgibbs
Joined Jan 29, 2010
18,849
That looks OK, we should be able to suggest a minor change to the P1 resistance chain.
Have you started building the project.?
Aurion45
Joined Aug 7, 2011
64
That fine ericgibbs.
ScottWang: ou don't need that much current, but if you want to and can buy it then it's OK.
Vds = Id * Rds
W = Vds * Id
So less Rds can reducing the power consumption.
OK will stick with the 5.3 mosfet.
ericgibbs
Joined Jan 29, 2010
18,849
hi,
For the LDR, instead of the bottom of the LDR being connected directly to 0v, connect it to 0v via a 39k resistor.
You should still have enough control with pot P1.
E
Aurion45
Joined Aug 7, 2011
64
Not good enough, hate Paint.
I'm using Diytrace Full Edition but finding it hard to use.
Also using Pad2Pad to make my boards, very easy to use.
Wendy
Joined Mar 24, 2008
23,421
Nope, Sorry, I was ... Squirrel!
I'll get er done this weekend. The idea is you can squeeze a power out the batteries with a joule thief arrangemet.
Aurion45
Joined Aug 7, 2011
64
Cool I'm looking forward to it, as I've got a handle at using Diptrace now, making patterns and components and circuits even make a QX5252F with T0-94 body pattern, as I'm mucking around with this chip as well.
Wendy
Joined Mar 24, 2008
23,421
OK, it always pays to define the circuit parameters before doing a design.
You want 53 LEDs? Just curious, why the odd number (and a prime to boot)? Are you trying to create a pattern?
We want to merge these two schematics...
The Joule Thief arrangement will run a 1 hz blinker for 1 month off two AAA batteries. It is pretty energy efficient.
Something to be aware of, you do not need to run LEDs full out all the time. I rarely do this, even when I am using them as a light source. An odd thing, but when they are flashing at intense brightnesses (from the 70Khz oscillator) they can appear brighter than the average power would indicate.
