The statement in the introduction says:
"When the polarity of the battery is such that electrons are allowed to flow through the diode, the diode is said to be forward-biased. Conversely, when the battery is backward and the diode blocks current, the diode is said to be reverse-biased."
It is best to rephrase it as follows:
"When the polarity of the battery is such that a current is allowed to flow through the diode, the diode is said to be forward-biased. Conversely, when the battery is backward and the diode blocks current, the diode is said to be reverse-biased."
This revision eliminates confusion in the current flow convention (flow of current to be from positive to negative poles in a DC circuit vs actual case of electrons moving from negative to positive poles), and follows with the remaining part of the sentence when it refers to current.
