I have heard that powder coating removes the electrical properties of metal.it becomes insulated.so you remove the powder coating(masking) where you require electrical connection
Kindly elaborate
Kindly elaborate
Doe most of the time plastic spray is used.Powder coat is basically melting plastic over and object- plastic is an electrical insulator- you must get under it to make electrical contact with the base metal.
Read post #3.are there any other option for spray ?
Basic paint is an insulator also.
Coatings are generally applied to eitherIs the only purpose of powder coat is for look or they have any other purpose also.
Sometimes i have seen even the inner metals are poweder coated which are not exposed in an product ?
by Jake Hertz
by Duane Benson
by Jake Hertz
by Duane Benson
