Challenging Laplace from diagram
Discussion in 'Homework Help' started by ihaveaquestion, Oct 12, 2009.
  1. ihaveaquestion
    Thread Starter Active Member
    May 1, 2009
    314
    http://img132.imageshack.us/img132/9986/2551copy.jpg
    There's my work... this one looks tough.
    Does this look right/wrong to anyone? I tried doing it in parts... the first slope using the idea of y=mx+b and same with the end slope... the middle was just 'normal' stuff, I'm not sure how to explain it... still learning this stuff.. thanks
  2. notxjack
    Sep 7, 2009
    20
    I have no idea what to make of your work. The way you should approach a question which is piecewise smooth is by integrating it piecewise inside each interval where the function behaves uniformally. Basically treat the function like:
    2x for x in [0,1]
    2 for x in [1,3]
    -2x+8 for x in [3,4]
    This yields a three term sum of integrals (L = e^(-st)):
    \int_0^1 \! L*2t \, dt.
    plus
    \int_1^3 \! L*2 \, dt.
    plus
    \int_3^4 \! (-2t+8)*L \, dt.
    LaTeX in a forum is just cruel. Can we have a clipart drawer app instead?
  3. notxjack
    Sep 7, 2009
    20
    I'm not sure whether my post is editing, but I see you're doing delay/shift theorems and that u is the step function. You should still be doing this in three parts, and your third part is still -2t+8 and not 2t as you have in your notes. When you have a broken up domain like this, you want to set it up as follows:
    2t[u(t)-u(t-1)]+2[u(t-1)-u(t-3)]+(-2t+8)[u(t-3)-u(t-4)]
    Idea being that as you go past each of the intermediate bounds (1, 2, and 4) your u(t)-u(t-a) terms will go to zero for the 'useless' parts of our piecewise definition.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    This was my approach - needs double checking.
  5. notxjack
    Sep 7, 2009
    20
    That 'looks' more correct, though I don't understand your graphical notation. The easiest way to break up problem into something more legible would just be to put dotted lines at each 'shift' and then write a roman numeral in each section, then list out each partial Laplace for each roman numeral, then sum them together. Re-drawing the graph at each stage both bloats your work as well as introduces opportunities for omission (such as mislabeling a point in the domain or range). Your graders will appreciate it.
    Ex:
    I. L(the u(t)-u(t-1) part)
    II. L(the u(t-1)-u(t-3) part)
    III. L(the u(t-3)-u(t-4) part)
    L(h(t)) = I + II + III = some expression in terms of s
    h(t) = the inverse Laplace transform of our L(h(t)) expression
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi notxjack,
    I'm not sure if your comments were addressed to me. Thanks for your feedback if they were. If so they brought a wry smile to my face - at the age of 60 years it's unlikely you're going to get this old dog to learn any new tricks or (alternatively) "make a silk purse from a sow's ear". Fortunately I don't have to suffer the strictures of grading by any professors these days. I'm also not sure what you mean by "more correct" - presumably one is or isn't correct.
    Apologies if you weren't commenting on my contribution.
    Rgds,
    t_n_k
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    And I do see where I am incorrect BTW. I don't need the two step bits I included.
    So the correct answer is (presumably) something like ...
    F(s)=(2/s^2)*(1-exp(-s)-exp(-3s)+exp(-4s))
    What do you think?
