Challenging Circuit
Discussion in 'Homework Help' started by parshu_hotkar, Oct 30, 2005.
  1. parshu_hotkar
    Oct 30, 2005
    Hi ! I have a Challenging Circuit quetion!
    Design a circuit 4 measuring speed of walking man .
    No ICs r allowed.Use only simple components!
    W'll se how many of u can solve this problem!
  2. pebe
    Oct 11, 2004
    628
    R U allowed 2 use any 4mula 4 the design
  3. n9352527
    Oct 14, 2005
    1,198
    What do we get if we can solve it? :p
  4. parshu_hotkar
    Oct 30, 2005
    [violet]Yes, u can use 4mula!
  5. mozikluv
    Jan 22, 2004
    1,437
    hello
    is this your way of asking for a schem of that circuit function? since no ic will be used then its discrete parts that has to be employed which translates to time and effort of designing that circuitry. so what do we get from this?
    moz
  6. n9xv
    Jan 18, 2005
    329
    I charge $200 / day plus expenses.
  7. Overclocked2300
    Apr 24, 2005
    124
    Is breakfast included? What about beautiful women?
  8. Firestorm
    Jan 24, 2005
    353
    What happened to doing this out of the goodness in your hearts :p. lol, whats the point of this, to waste time to complish nothing for a cause or contest in which hardly anyone is competing in? Sorta confused on this purpose?
    -fire
  9. mozikluv
    Jan 22, 2004
    1,437
    hi fire,
    don't get confused. remember this is a homework forum. we can only guide and let the person do somemore research so he could fully grasp the function of each part. and another thing the circuit is not an off-the shelf circuit design. :lol:
    moz
  10. Brandon
    Dec 14, 2004
    306
    Sounds like a little mini project for school..
    hmmm... try thinking out of the box?
    For instance, spool of thread attached to the ground at reference point, spool its part of the circuit. Make some form of mechanical switch (like brushes in a DC motor) as part of the spool. As the thread is pulled off of it, it will spin and you can use a fairly simple difference amplifier setup with a few transistors to cause a led to flicker. Its rate of flicker is proportional to the speed of the spinning spool = walking speed.
  11. Firestorm
    Jan 24, 2005
    353
    O I gotcha, I was skimming it a lil' too quickly. Wish I had time to try out some circuits again, school work sucks! Thanks for the clarification.
