Chaining Binary Counters?
Discussion in 'Electronics Resources' started by JacobEdward, Apr 29, 2015.
  1. JacobEdward
    Apr 29, 2015
    23
    I was reading this article:
    http://www.allaboutcircuits.com/vol_4/chpt_11/3.html
    when I started looking for pre-configured binary counters (that's a lot of discrete components to put on a circuit board...) and discovered that a typical 4 bit binary counter is around 40 cents while 8 bit binary counters are like 10 bucks... Is it possible to chain a couple of binary counters together (sorta how shift registers are chained together)?
    http://www.digikey.com/product-detail/en/CD4029BE/296-2046-5-ND/67275
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    It is certainly possible. It's how things were done before there was an 8 bit part. A typical example would be the the 74LS161 synchronous counter.
  3. JacobEdward
    Apr 29, 2015
    23
    Great :) though is this a up/down counter?
  4. JacobEdward
    Apr 29, 2015
    23
    Lol, man, so this synchronous counter takes 4 input data lines? You wouldn't happen to have a tutorial handy that would explain how to use this thing would you? Going through the data sheet right now.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
  6. JacobEdward
    Apr 29, 2015
    23
    yea... not sure if you read the first post, but I actually linked to that exact page... the page doesn't explain how a binary counter accepts 4 data lines...
  7. absf
    Dec 29, 2010
    1,493
    374
    Here's one way to connect 2x 74HC161 to become an 8 bit binary counter.
    The preset inputs are used to start counting up from any 8 bit value eg 0-255. You can leave them out and just connect /load pin to logic high so it would always start counting from zero.
    Allen
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You're right I did not follow the link to see what you were reading. I tried to answer the cascade question in the affirmative, and I was looking for material on preloading. Thing is, you may or may not be aware of the datasheet which exists for almost every part you can imagine. They are just chock full of useful pictures, diagrams, graphs, and charts. In the not so distant past engineers would collect libraries of databooks. Nowadays we just google them as in:
    "74LS163 datasheet"
    http://www.ti.com/lit/ds/symlink/sn54163.pdf
    Notice the diagram on page 4 which shows how the DATA inputs can be routed to the J K inputs of the flip-flops conditiond by LOAD-bar. The short answer is that the data inputs are routed to the JK inputs by using a multiplexer.
  9. JacobEdward
    Apr 29, 2015
    23
    Yea... I already mentioned that I was reading the counter's datasheet... In the future, can you not respond to a question or comment until you've actually read what I said? Thanks
