Ceramic Capacitor ID Help
Discussion in 'General Electronics Chat' started by TrevorFormosa, Feb 25, 2016.
  1. TrevorFormosa
    Feb 25, 2016
    12
    Hi have a Ceramic capacitor in an charger i need to replace. its split right down the middle I cant figure out the id on it. The only numbers on there is the first line says 240 the second line says L012. Can someone please tell me what capacitor i need to replace this and i can buy it on amazon!
  2. #12
    Nov 30, 2010
    16,705
    7,358
    2,4,0 would say 24 pf to some people, but nobody wants to stick their neck out without more information. 24pf is pretty small, high frequency stuff, out of range of most switching power supplies. How about a photo?
  3. TrevorFormosa
    Feb 25, 2016
    12
    I was feeling the same on the 24pf but I just don't know about that. I will upload a pic in a minute
  4. Sinus23
    Member
    Sep 7, 2013
    178
    482
    That is a pretty big "24pF"? ceramic cap to have all those numbers on it. Like #12 said a photo would help.
  5. TrevorFormosa
    Feb 25, 2016
    12
  6. #12
    Nov 30, 2010
    16,705
    7,358
    That looks wrong. I'm thinking a power line protector of some sort. Back up the camera a bit so we can see what is nearby. Maybe get a better clue.
  7. TrevorFormosa
    Feb 25, 2016
    12
    Sorry poor pictures I hav e left the shop for the day and have another employee sending me pictures.
  8. TrevorFormosa
    Feb 25, 2016
    12
    PS they ripped it out... So all there is is two dots beside those neutral wires there
  9. TrevorFormosa
    Feb 25, 2016
    12
    Could it possibly be a varistor? But of what type I found a L06 varistor but no L012. I don't know very much about them.
  10. seanstevens
    Member
    Sep 22, 2009
    25
    It looks like a 240V varistor. It also looks like your device had a voltage surge making the varistor to open up like that. As varistors are over voltage/surge protector, it must have had a big surge to do that to it.
    If the varistor reacted fast enough, your fuse would have gone and hopefully nothing else downstream is damaged by the surge. If no other damaged then the device should work without that part (as a test only), however the varistor should be replaced to take care of the next surge. If the unit doesnt work without the part then other parts may be damaged.
    BW, the varistor would sit between live and neutral, if it is in series it might be thermistor to reduce inrush current.
  11. TrevorFormosa
    Feb 25, 2016
    12
    So if I jumper this area and I have success cab I just throw in any 240 varistor?
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The datasheet says it is a PTC or polyfuse.
    Bertus
  13. TrevorFormosa
    Feb 25, 2016
    12
    Hi bertus. I got a "data sheet cannot be displayed" error. Any other way of sourcing?
    Thanks!
  14. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Strange it is a basic PDF file.
    I have copied the first page from the datasheet as an image:
    Bertus
    Sinus23 likes this.
  15. TrevorFormosa
    Feb 25, 2016
    12
    Thanks Bertus. How does one go about purchasing something like this. They are not on Amazon as far as I saw
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  17. TrevorFormosa
    Feb 25, 2016
    12
    Well the way i understand it is the customer has a really old Honda generator. He has had problems in the past with these charger inverters due to his generator. I am recommending him a new one
  18. TrevorFormosa
    Feb 25, 2016
    12
  19. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The difference is the shape of the legs:
    Bertus
  20. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    Probably something pretty drastic to do that to a PTC thermistor, I'd be looking for what caused it before just bunging another one in.
