Centripetal acceleration derivation
Discussion in 'Physics' started by logearav, Sep 30, 2011.
  1. logearav
    Aug 19, 2011
    248
    Revered members,
    Please go through my attachment, which describes the derivation of centripetal acceleration.
    Change in velocity along horizontal direction = vcosdθ - v
    Change in velocity along vertical direction = v sindθ - 0
    change in velocity means final velocity - initial velocity
    why V is taken as initial velocity in horizontal direction and 0 is taken as initial velocity in vertical direction?
  2. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Simply put, because of the chosen initial conditions. Look at the diagram in your first attachment.
  3. logearav
    Aug 19, 2011
    248
    Thanks BillO. But i can't figure out what are the initial conditions. Velocity acts tangentially at the points A and B. Thats all i could figure it out.
  4. BillO
    Nov 24, 2008
    985
    136
    It's where the angle is measured from. They chose to start measuring the angle from point A.
    In the attached drawing we have a particle p traveling around the shown circle with velocity v. we can break v down into horizontal and vertical components vx and vy.
    Using angle a;
    vx=-vsin(a) and vy=vcos(a)
    Using angle b:
    vx=-vcos(b) and vy=vsin(b)
    So sin(b)=cos(a) and cos(b)=sin(a).
    Can you see what I mean now?
      File size:
      5.3 KB
      71
  5. logearav
    Aug 19, 2011
    248
    i feel embarrassed to say that i don't understand. My poor basics is the reason for that. I apologize for wasting the time of you, by my stupid questions.
    I interpreted in this way, change in velocity in horizontal direction is
    vcosdθ - vcos(0) so vcosdθ - v
    Similarly change in velocity in vertical direction is vsindθ - vsin(0) which
    vsindθ - 0.
    I don't know whether i am correct.
  6. BillO
    Nov 24, 2008
    985
    136
    logerav, there is no such thing as stupid questions, there are only just stupid answers. If you are not getting my answers, it is my failing, not yours.
    Give me a little time to think about how I should help with this.
  7. logearav
    Aug 19, 2011
    248
    BillO, thanks for your constant support and encouragement. Regarding your diagram in
    post #4, i tried to resolve the velocity into its horizontal and vertical components, both for angle 'a' and angle 'b'. Please tell if i proceeded right.
    Change in velocity in horizontal direction = vcos(b) - vsin(a)
    Change in velocity in vertical direction = vsin(b) - vcos(a).
    Now what is the value for the angle 'a' and 'b'?
      File size:
      244.8 KB
      33
  8. BillO
    Nov 24, 2008
    985
    136
    Hmmm...
    Angles a and b are continuously changing as p moves around the circle. They also follow the relationship;
    a + b = pi/2
    Now, p is moving around the circle in a counter clockwise direction with angular velocity v.
    So, if we want to decompose v down into its x and y components we must choose an angle.
    If we choose angle a to do our decomposition, then:
    The component of the velocity in the x direction = -vsin(a)
    The component of the velocity in the y direction = vcos(a)
    This is all we need. You had asked why cos and/or why sin were chosen, and I told you it was because of the angle that was chosen. So to demonstrate this, if, instead of angle a, we happen to choose angle b, then:
    The component of the velocity in the x direction = -vcos(b)
    The component of the velocity in the y direction = vsin(b)
    You do not need both a and b. Just pick one or the other. Either one is fine, it's just that the functions you will use will change as noted above.
  9. logearav
    Aug 19, 2011
    248
    Thanks a lot BillO. But, why its negative i.e., -vsin(a) and -vcos(b)?
  10. BillO
    Nov 24, 2008
    985
    136
    So as to make the direction along the x axis correct. As you can see, when p gets to the top (a=pi/2 or b=0) it is moving directly in the negative direction parallel to the x axis.
