What I mean by this is a motor with a large hole in the middle, instead of a shaft.
Some motors I found allow to easily remove the shaft, but the bore/shaft diameter I need (at least 4 cm) and RPM (700-900) are not even close.
Where can I find such a motor?
(the motor has to be small. Why it is needed: http://i.imgur.com/eoL79BU.jpg )
