celing fan speed too slow
Discussion in 'General Electronics Chat' started by dmta, Aug 10, 2013.
  1. dmta
    Mar 24, 2013
    32
    Hi all,
    I am having the following problem in my celing fan except for the fact that it has 5 speeds. What to do ?
    Regards
      File size:
      101.3 KB
      83
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    That kind of fan there is no any protection, so the speed can't too fast, otherwise when the fan is working and the blades left the fan that it may kill someone.
  3. wmodavis
    Oct 23, 2010
    737
    150
    You might look inside for a capacitor and replace it with one of equal ratings and see if that helps. I have done this when fan was running slow with good success.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    If it is the simple triac controller at the light switch position, it could be this defective.
    Max.
  5. #12
    Nov 30, 2010
    16,703
    7,338
    The old Hunter brand fans were famous for "barely moving". If everything checks out when measured, you might have to conclude that it was designed to run very slow. Still, checking its parts is a good thing. You can't be sure until you examine it.
  6. dmta
    Mar 24, 2013
    32
    Hi guys,
    I think the picture may have misled some of you. The actual thing doesn't look like the pic. BTW the fan is a KDK brand :D
  7. #12
    Nov 30, 2010
    16,703
    7,338
    That's OK. We spend a lot of time here responding to false or missing information.
  8. msak671@hotmail.com
    Aug 4, 2013
    8
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The AC motor in a fan runs in a state of "slip" so the speed you get is determined by the input power compared to all the drag forces.
    If there is a high drag force (like a bearing that needs lube) the fan will run very slow. Other symptoms of bearing drag will be that the fan is very slow, but can speed up if left running (as bearings warm up and loosen).
    Spray a heap of lube in there, but pick a lube that doesn't smell too much. :)
