CE Amplifier Input Impedance question
Discussion in 'Homework Help' started by ECE101, Nov 26, 2011.
  1. ECE101
    Nov 25, 2011
    29
    I'm trying would the input impedance would be for the circuit shown below..
    I understand the input signal will see the Beta*Re resistance, but if I assume the constant current source is a resistor, would it just be:
    Rb || Beta*Re?
    I've seen it defined as Re + (1 + Beta)*RE
    where RE is an emitter resistor, as there is no RE in this diagram I'm not really sure how to derive the input impedance.
    Any advice would be appreciated!
  2. mik3
    Feb 4, 2008
    4,846
    63
    The input resistance Rin=Vin/Iin.
    Find Vin and Iin and divide them.
    ECE101 likes this.
  3. ECE101
    Nov 25, 2011
    29
    Thanks for the reply milk3!
    I've just found the answer and
    Rin = Beta/Gm (or Beta*Re as I suspected)
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Rin = RB|| ( Beta + 1) * re
    re = 26mV/Ic ---> dynamic emitter resistance ( looking into the emitter to base).
    And this intrinsic resistance (re) acts as if is is in series with the emitter.
    gm = 1/re
    ECE101 likes this.
