Thanks... what i need is only the hold/pause function for Q and Q_bar (pin 10,11).. from your reply, i hope that can be done..While the 4047 has several flipflops in it, none of them are configured as data latches (if that's what you meant by "memory"). As for the hold/pause, both the True and Complement Gating inputs allow this. BUT - as indicated in the logic diagram on page 2 of the datasheet, pausing the astable terminates the current clock cycle. If the output (pin 13) already was in the low state, it just sits there. If it was in the high state, it drops low immediately and sits there. Thus, when enabled the oscillator always starts out with a clean first cycle.
ak
Thread starter | Similar threads | Forum | Replies | Date |
CD4047 ,Mosfet IRFP150 Inverter | Analog & Mixed-Signal Design | 36 | ||
CD4047 Inverter, solar powered | Power Electronics | 21 | ||
N | CD4047 Retrigger mode | Digital Design | 4 | |
Looking for LTspice modules of CD4047 and MC14528B | PCB Layout , EDA & Simulations | 27 | ||
U | CD4047 mono/astable multivibrator | General Electronics Chat | 2 |
by Jake Hertz
by Jake Hertz
