cd4046 wave form problem
Discussion in 'Analog & Mixed-Signal Design' started by Amir Sarikhan, Jun 30, 2016.
  1. Amir Sarikhan
    May 29, 2015
    45
    Hi all
    I used a cd4046 to to produce a square and triangle wave
    It has a constant current on the capacitor pin so producing also a triangular wave form on that pin . The circuit works well at pspice
    but in my board I get different results as pictures below
    please help me
      File size:
      114 KB
      43
      File size:
      61.2 KB
      43
      File size:
      46.8 KB
      40
  2. crutschow
    Mar 14, 2008
    13,503
    3,376
    You don't show a schematic of the constant-current source and my crystal ball is out-of-order, so how can we tell what's wrong?
  3. Amir Sarikhan
    May 29, 2015
    45
    Hi thanks for your response . I read on a web site that it has some kind of constant current on capacitor pins and it is shown on spice simulation but the problem is that on board I did not get same result .what is the reason ?
  4. Alec_t
    Sep 17, 2013
    5,977
    1,136
    We can't see your board from here!
  5. Amir Sarikhan
    May 29, 2015
    45
    my board:
  6. Ramussons
    May 3, 2013
    562
    92
    How does the modern generation do "electronics" without a schematic ? :confused::eek:
  7. Amir Sarikhan
    May 29, 2015
    45
    I sent pspice schematic .
  8. Amir Sarikhan
    May 29, 2015
    45
    Friends please reply me if you do not receive my pictures .
  9. Kjeldgaard
    Member
    Apr 7, 2016
    73
    17
    Now I have to refresh how the VCO in the 4046 is constructed. A example of the data sheet can be Texas Instruments: CD4046
    On page 11, there is an expanded block diagram of the VCO. It can be seen that the timing capacitors one end is connected to ground when charging with the constant current of opposite end of the capacitor, and after a half cycle time is changed to the opposite terminals of the capacitor.
    So that will measure a sawtooth curve when measured at one end of the time capacitor.
    Amir Sarikhan likes this.
  10. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Try connecting the resistor that presently goes to pin 12 to pin 11 instead.
  11. crutschow
    Mar 14, 2008
    13,503
    3,376
    Why do you have pin 15 connected to V+?
    It should be left open or connected to ground.
  12. Amir Sarikhan
    May 29, 2015
    45
    it is connected to ground not v+
    thanks
    I read that page
    you say right
    but why pspice draws a triangular wave ?
  13. crutschow
    Mar 14, 2008
    13,503
    3,376
    Yes, I mis-traced the connection.
    Kjeldgaard is correct. You will measure a sawtooth voltage from one end of the capacitor to common as the circuit shows.
    What, exactly is the Pspice plot measuring?
  14. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Do you now have a resistor between pin 11 and ground?
  15. ramancini8
    Member
    Jul 18, 2012
    447
    119
    This is a good example of why you should not DESIGN with a program, any program.
  16. Amir Sarikhan
    May 29, 2015
    45
    Yes , of course
    I think so
  17. crutschow
    Mar 14, 2008
    13,503
    3,376
    I meant at what point in the circuit is the Pspice voltage being measured?
  18. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Can you post a link to the Pspice model of the 4046? The spice model I downloaded doesn't work properly.
  19. Amir Sarikhan
    May 29, 2015
    45
    Hi sorry for late response
    I did not download it , it was in my library list
  20. schmitt trigger
    Jul 12, 2010
    46
    8
    If you require to generate a triangular wave from a square wave, use an integrator.
