hello, im building this relay selector circuit, and had a few basic questions
if i want to take the reset function out do i still have to ground pin 15 with the 10k resistor? also would i still need the other 10k resistor next to S1?
im buying all my parts from allelectronics and they don't have the 2N7000 transistor. can you recommend a different transistor that they sale that the CD4017 can drive? here are the relays im going to use. also with the suggested transistor would the 100 ohm resistor be fine?
thank you
seesoe
thank you
seesoe
