cd4017 Code lock
Discussion in 'The Projects Forum' started by xile6, Jun 19, 2011.
  1. xile6
    Jun 9, 2011
    10
    Ok so i was looking around for a electronic code lock.
    Ended up find this. Attached below.
    well it uses a cd4017 which i never worked with before. I understand the diagram. I just have some questions.
    first do i have to use Q1-Q9 and output on Q10 or can I make my code shorter and just use Q1-Q4 and output on Q5?
    Also i can wire all the non-code keys to S10 for reset? So if the wrong key is pressed it will reset the chip.
    And can i use a 2n3904 transistor? The diagram calls for a sl100 which i am having problems finding. but i have about 100 2n3904.
    thank you for any answers you can give.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Yes to all.
    Here's the complete article: http://www.electronicsforu.com/EFYLinux/circuit/January2010/Simple%20Code%20Lock.pdf
    You can use a plugboard type set of connections to change the code without moving or rewiring switches.
  3. xile6
    Jun 9, 2011
    10
    yes i have that pdf just didnt know how to post it.
    what i really want to know is do i need to use all 9 for the code or can my code be 4 long and just output on 5?
  4. Pencil
    Dec 8, 2009
    271
    38
    Yes.
    Here's a datasheet for the 4017 if you do not have one.
