Yes. Every time we crossed the area, quite close to your country, weather was humid and mostly hot.Might be due to the high humidity in the place I live.
Allen
So, if this isn't the real circuit you should post the real one. If it is. What powers the IC's??I'm working on a wooden table. Here is a portion of my circuit containing the NAND's. Obviously i'm using this circuit twice, and they are only connected to one another by utilising the same power source. The LTSpice circuit doesn't show the power source, but this is done as the same way as these inputs is, using a 7809.
The other major difference is that i'm using a BC548B in place of the BC847C (couldn't find a model of it, so used the next closest equivalent)
As I say, the circuit is working and doing what i want it to do, but ONLY on one circuit with the two NAND chips that are actually working...!? The other half wont work with another other chips, but will work with the two i have working, when i swap them over to that side.
555 ics are not sensitive very much.@Rissy,
Please send me a list of sellers that you purchase ICs from. I am very cautios when purchasing parts for the very reason that they may be fake or damaged. I have even had dodgy parts from reputable sellers!
Also here is something for everyone to have a chuckel on:
I purchased 50 555Ic's once from a reputable supplier on ebay. But what arrived was polysterine wrapped in foil with the parts pushed in. This would normally be OK if there is ALOT of thick foil but this was the thinnest foil you could find with only one wrap and half the pins where left unconnected. I had to throw them away because I could not risk one of these devices failing
We dont need exaggeration of this kind on the forum....although, even once i CAN report, i'm sure i'll still be confused. Because as i said, although the other remaining chips wouldn't work on my circuit, they did mostly check out ok using a multimeter on some breadboard with 12V shoved up their arse.
Yes I know. I'm sorry. I've just been very frustrated with this project over the past few weeks.We dont need exaggeration of this kind on the forum.
Your right about 555 chips not being very sensitive to static however they are still prone to static damage. There is no harm in making sure that all components are stored correctly. I have sold many hundreds of kits with zero reports on failed chips.555 ics are not sensitive very much.
I'm keeping all the large ics I'm selling in plain plastic drawers then usually wrap with tin foil. Also I use antistatic bags sometimes.
The warehouse is metal frame, no carpets, humidity is high. There's no static in the first place.
Getting very few claims of defective ics and I sold 1000s. This is from old ics which already were defective.
I don't understand your reasoning for using the 7809s. With only a CMOS input for a load that is below recommended specs for a 1 Amp regulator. Even for a 78L09 (100 mA) regulator.This is my circuit.
When the side lights are off. So are the Orange LED markers.
When the side lights are on. So are the Orange LED markers.
When the side lights are off, and then the indicator is on, then the appropriate side Orange LED marker flashes in time with the Indicator until indicating is cancelled and then returns to the off state.
When the side lights are on, and then the indicator is on too, then the side light request to the appropriate Orange LED is overridden by the indicator request, causing it to flash in time with the Indicator until indicating is cancelled, and then returns to the on state.
The pulse converters seem to be the only parts of the circuitry which are working. The 4011 element of the circuit(s) only seem to work with this one rogue chip, as described above....!? why? I need help to fix this. Please.
If you say so,No it wouldn't. I need to regulate all the inputs to the logic to the same level as VDD. So, side lights and indicator (pulse and constant separately)
The reason I picked 9v is because an automotive environment can swing between 10.5v - 14v depending on whether the engine is running or not etc.
So that's a problem...because drop out for the regulator is 2v (like I mentioned in a previous post). This means the voltage into the regulator must be higher than 11v.No it wouldn't. I need to regulate all the inputs to the logic to the same level as VDD. So, side lights and indicator (pulse and constant separately)
