What, no styrofoam???It is a sheepskin with deep pile wool wrapped with latex balloons.
Then I see you are practicing good anti-static protocol.It is a sheepskin with deep pile wool wrapped with latex balloons.
One of the first tricks I was taught in my career, was to hold static sensitive devices by the encapsulation and breathe on the pins just like you'd do before polishing spectacles. The condensation gently dissipates any static charge on the device.Hey folks,
I'm working on a project which uses Texas Instruments CD4011BE NAND IC's. I'm finding a lot of them are going into the bucket due to them not working properly. I've been designing a circuit for the past couple of months, and have finished prototyping each component area of the overall circuit, and everything has been going well. Now however, i'm tryinig to get the main logic brain of my circuit working and have found that out of about 22 NAND chips i've bought, only 2 actually work in my circuit. I need four in total to work the whole thing. I've ordered another 16 from a seller on Ebay and i'm waiting for delivery later this week.
The two I have which work on one half of my circuit, i've moved between positions to the other half of the circuit, and have proven that they work wherever I put them. But as I say, these are TWO....of around 22! Out of the failing ones, I've resisted throwing about 10 of them straight into the bucket, and gone through the laborious exercise of testing them with a multi meter instead; testing each NAND gate in turn with all four permutations of input possible states. From this testing, I threw 4 away because I confirmed that, for whatever reason, one or more of the gates wasn't working properly. This left me with 6 (in addition to the 2 working ones) which tested fine with my multi meter testing, yet they still wont work with my circuit!? I'm most confused!!!??
Has anyone else had a great amount of difficulty with these chips? Am I destroying them with static even though i'm gingerly handling them with kid gloves, touching only the back plastic body?
any help/advice?
Like say, they seem to work with a multi meter, at least the remaining ones i've not found a fault with and thrown in the bucket. they work under test ,but once i plug them into my circuit, they don't, even though the two "good ones" do work in the exact same positions!?
Another common error is when using a C/R to apply a pulse during power up. A diode from cap to Vdd must be used to discharge the cap when Vdd goes down at power off.Is it possible that one of your inputs at power on is at 9 volts before the power supply for the IC's get their 9 volts?
I'm aware of this. But i had chips which weren't sticking to the expect truth table results, and even had a couple which were giving me random voltages like 6V etc. weird.That's the correct function for NAND. Zero on any input gives 1 out; both 1 gives 0 out.
I deleted my post because I misread your post. You saw it before it got removed.I'm aware of this. But i had chips which weren't sticking to the expect truth table results, and even had a couple which were giving me random voltages like 6V etc. weird.
I bought hundreds of components from an eBay seller who seemed to be buying in bulk and packaging in lower quantity at a price better than all on-line sources. I received dozens of CMOS ICs packaged in a polystyrene type material and put in regular zip lock bags.I purchased 50 555Ic's once from a reputable supplier on ebay. But what arrived was polysterine wrapped in foil with the parts pushed in.
