CD40106BE Oscillator Not Working HELP!
Discussion in 'The Projects Forum' started by PandaHero23, Jun 16, 2016.
  1. PandaHero23
    Jun 16, 2016
    19
    I wanted to make an oscillator out of a cd40109be chip so i looked up some tutorials on how to do it, i followed the tutorials and made sure i got everything right. but when i plunged a speaker in to the output and to ground nothing happened, so i used an LED but still nothing. I'm using a 9v battery to power the circuit on a breadboard and i got the chips from texas instruments via amazon. i am new(ish) to electronics so I'm probably doing something wrong, any ideas? thanks! :) heres some pictures of the circuit (there is also more information after the pictures):
    The red alligator clip is going from the output of the inverter into the positive input of the speaker and the white alligator clip is going to ground and is connected to the negative input on the speaker (the speaker is an Adafruit 3inch speaker) heres the tutorial i followed: http://hackaday.com/2015/02/04/logic-noise-sweet-sweet-oscillator-sounds/
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Put a 0.1 uF decoupling capacitor (ceramic) as close as you can across the "positive" and "negative" leads.
    Ground your unused inputs.
    John
  3. AlbertHall
    Jun 4, 2014
    2,261
    447
    Standard loudspeakers are very low resistance (less than 10 ohms). That is much too low for the chip to drive and it will stop the oscillator dead. Try connecting the speaker through a small capacitor (perhaps 1uF?).
    Also the capacitor in your picture looks like an electrolytic which will probably be too big to make an audible tone. What value is it?
  4. PandaHero23
    Jun 16, 2016
    19
    its an electrolytic 0.1uF compositor
  5. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    Not sure what a compositor is but it definately looks like an electrolytic which makes it unlikely to be 0.1uF?
    Can you tell us what's written on this capacitor?
    You need something like a 0.1uF polyester capacitor.
  6. PandaHero23
    Jun 16, 2016
    19
    opps, autocorrect lols. i checked the capacitor and it says its 0.1uF, heres a picture:
  7. Alec_t
    Sep 17, 2013
    5,968
    1,135
    You should just about be able to drive an LED with that chip, but certainly not a loudspeaker.
  8. PandaHero23
    Jun 16, 2016
    19
    i did get an LED to light up with the output but no oscillation.
  9. dl324
    Mar 30, 2015
    3,376
    651
    With 10KΩ and 0.1uF, I calculate a frequency of around 600Hz. Too fast for you to see the LED blink.
    Show how you had the LED connected. If you loaded the oscillator, you'd change the frequency.
  10. PandaHero23
    Jun 16, 2016
    19
  11. GopherT
    Nov 23, 2012
    6,303
    4,020
    @PandaHero23
    That chip is a hex inverter, to prevent loading the oscillator with your LED, put the output of your oscillator to the input of a second inverter (on that chip). Light your LED with the second inverter.
    Also, put a 470 to 1k resistor in series with that LED because you may damage the chip if you don't limit the current flowing out (an LED does not limit current).
  12. dl324
    Mar 30, 2015
    3,376
    651
    It's 10K brown-black-orange; 100K would be brown-black-yellow.
    You should have a current limiting resistor for the LED and you should use one of the other inverters to buffer the oscillator so you don't load it and change the frequency.
  13. PandaHero23
    Jun 16, 2016
    19
    so in the end, how would the circuit look on a breadboard?
  14. GopherT
    Nov 23, 2012
    6,303
    4,020
    It should look like this.
    Your resistor looks like a 10k, not 100k. If you don't have a yellow band, 100k resistor, then you'll definitely need a bigger cap. I think your 0.1F will be flashing 100x per second (100hz) and you won't tell if it is on or off by sight (you'll need a scope or signal counter).
    Use a cap in the range of 10u to start out with a 100k resistor. Adjust parts from there.
    As I mentioned above. Put a buffering, extra, inverter between RC network and LED. Also use the current limiting resistor on the LED.
    See below
  15. Bordodynov
    May 20, 2015
    670
    194
    GopherT.
    Attention!
    Input pins CMOS logic should be connected (3A,4A,5A,6A). In this case, they can be connected to ground or to the power supply.
    In the opposite case, the consumption current will be not determined. Although the circuit will operate.
  16. Alec_t
    Sep 17, 2013
    5,968
    1,135
    The LED without a series resistor is too great a load for the IC and prevents oscillation.
    Pins 3,5,9,11,13 of the 40106 IC are presently unused gate inputs. Connect all unused inputs to ground (or to the +ve supply rail), as Bordodynov says. CMOS circuits behave erratically if input pins are left floating.
  17. dannyf
    Sep 13, 2015
    2,196
    417
    the led is holding the output to a level that may not be recognized by the input as high.
    you will need to put a resistor in serial with it.
    generally posting a schematic is more helpful.
  18. GopherT
    Nov 23, 2012
    6,303
    4,020
    Thanks for the "heads up". Fixed.
  19. dannyf
    Sep 13, 2015
    2,196
    417
    I did a quick sim for you. the oscillator does about 15ms periods -> 600Hz. So even if the oscillator is working, your eyes wouldn't be able to tell - the led looks constantly lit.
    You can use a resistor to isolate the led from the chip's output, or since you have unused gates, you can use one of them to buffer the output then no need for that resistor.
    Alternatively, use an led with high forward voltage, like a blue / white led. It helps with low supply as well.
  20. AlbertHall
    Jun 4, 2014
    2,261
    447
    Er... 15mS is about 60Hz?
