CD rom brushless motor
Discussion in 'General Electronics Chat' started by aconz2, Mar 6, 2010.
  1. aconz2
    Feb 8, 2010
    16
  2. VoodooMojo
    Nov 28, 2009
    503
    53
    attached is the application example that is pretty straight forward.
    the outputs (A1 A2 A3)
    The Vcc input for power supply and the motor power inputs 25 26 27
    The Absolute Maximum sheet gives you parameters to explore.
    information on your motor will be helpful.
  3. VoodooMojo
    Nov 28, 2009
    503
    53
    more pertinent info
    note Vcc, VM1 and VM2 values at top of sheet.
