CCVS in LTSpice netlist
Discussion in 'General Electronics Chat' started by Uul Sid, Dec 29, 2015.
  1. Uul Sid
    Dec 26, 2015
    Hi, i'm learning about spice netlist recently and i've got a problem with linear dependent sources.
    Here is my netlist source code.
    Example 1 : DC Voltages of a linear Network
    **Rangkaian**
    *Sumber independen
    Vs1 n1 0 1V
    Vmeter n7 n2 0V
    Vs2 n2 n3 6V
    Is1 n6 n4 1.5A
    *Sumber dependen
    *Sumber dependen CCVS (Current Controlled-Voltage Source)
    H1 n5 0 Vmeter 2
    Vmeter n7 n2 0
    *Sumber dependen VCCS (Voltage Controlled- Current Source)
    G1 n4 0 n4 n3 4
    *Elemen rangkaian
    R1 n1 n7 1ohm
    R2 n4 n3 3ohm
    R3 n2 n5 2ohm
    R4 n1 n6 5ohm
    **Output**
    .TRAN 1ms 50ms 0ms 1ms
    .END
    when i run it, there is a message says multiple instances of "Vmeter".
    Any idea what's the problem?
    I used spice second edition by sedra and roberts. It appears that there is the difference about dependent source syntax betweem LTSpice and sedra's book. I've searched the internet but i get nada. Thanks for ur help.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
