I've just completed the smoke test of these two CCS. They work as expected until I leave them unloaded and the voltage control is in any position other than fully turned OFF; in few seconds the respective op amp starts to warm up.
After some thinking I understand that by not having load, the opamp sinks / sources current from / to its corresponding Darlington trying to balance both inputs what never happens.
What could be the solution? For a moment I thought to use kind of a bleeding load similar as in voltage regulators but I discarded th idea. If the resistor is too high I will be in a situation similar to what I describe and, if too low, too much of my current wil be going through there.
For a moment I considered a base resistor but it seems useless as well. Or tell the user (me) to keep them fully turned OFF when not loaded? This last seems typical of a bad design.
Suggestions or comments appreciated.
