Code:
* Program starts here *
ORG $2400
START
* LDS #$23FF set stack pointer, DO NOT set when running under monitor
JSR ONSCI initialize serial port
LDX #MSG get message string
JSR OUTSTRG send it out serial port
** PART 3A
SEV
CLV
SEI
CLI
SEC
CLC
LDAA #$01
NEGA
NEGA
CLRA
** PART 3B
LDAA #$10
LDAB #$0F
LDD #$FEEF
LDX #$4D
TAB
CLRA
CLRB
** PART 3C
ADDA #$F0
SUBB #$B0
INCA
DECB
CLRA
CLRB
** PART 3D
LDAA #$01
LDAB #$01
ANDA
ORB
EORA
ORA
CLRA
CLRB
** PART 3E
LDAA #$2F
LDAB #$CF
LSLA
ASLB
RORB
ROLA
CLRA
CLRB
*** PART 3F
LDAA #05
LDAB #04
BITA #06
CMPB #07
TSTA
CPD #$FF22
CLRA
CLRB
** PART 3G
LDAA #05
LDAB #04
SBA
BLT SOMEWHERE
BGE SOMEWHERE2
BEQ SOMEWHERE3
BRA SOMEWHERE4
TWOE
LDAA #04
LDAB #05
SBA
BLT SOMEWHERE
BGE SOMEWHERE2
BEQ SOMEWHERE3
BRA SOMEWHERE4
THREEE
LDAA #05
LDAB #05
SBA
BLT SOMEWHERE
BGE SOMEWHERE2
BEQ SOMEWHERE3
BRA SOMEWHERE4
FOURE
LDAA #04
LDAB #05
SBA
BRA SOMEWHERE4
SOMEWHERE CLRA
CLRB
JSR TWOE
SOMEWHERE2 CLRA
CLRB
JSR THREEE
SOMEWHERE3 CLRA
CLRB
JSR FOURE
SOMEWHERE4 CLRA
CLRB
** PART 3H
JMP SOMEWHERE5
SOMEWHERE5
JSR HOWDY
HOWDY
BRA HOWDY2
HOWDY2
BRN
eloop nop endless loop
bra eloop
RTS
* ONSCI() - Initialize the SCI for 9600
* baud at 8 MHz Extal.
ONSCI LDAA #$30
STAA BAUD baud register
LDAA #$00
STAA SCCR1
LDAA #$0C
STAA SCCR2 enable
RTS
* OUTSTRG(x) - Output string of ASCII bytes
* starting at x until end of text ($04).
OUTSTRG JSR OUTCRLF
OUTSTRG0 PSHA
OUTSTRG1 LDAA 0,X read char into a
CMPA #EOT
BEQ OUTSTRG3 jump if eot
JSR OUTPUT output character
INX incriment pointer
BRA OUTSTRG1 loop
OUTSTRG3 PULA
RTS
* OUTCRLF() - Output a Carriage return and
* a line feed. Returns a = cr.
OUTCRLF LDAA #$0D cr
JSR OUTPUT output a
LDAA #$00
JSR OUTPUT output padding
LDAA #$0D
RTS
* OUTPUT() - Output A to sci.
OUTPUT
OUTSCI2 LDAB SCSR read status
BITB #$80
BEQ OUTSCI2 loop until tdre=1
ANDA #$7F mask parity
STAA SCDAT send character
OUTSCI3 RTS
*** TEXT TABLES ***
*MSG FCC ''
FCB EOT
* org $FFFE set the reset vector
* fdb START
END
I have written my different codes that is classified as a)condition b)data transfer c)arithmetic d)logical e)shift/rotate f)compare/test g)conditional branch h)unconditional branch
The next step to to Trace this. when opening the Tera Term and typing "T" Only three lines are being displayed repeating over and over. Am I now using the Trace command correctly? I'm trying to demonstrate and verify that my operations to each part works.
