Caution about ExpressPCB
Discussion in 'Electronics Resources' started by beenthere, Jan 20, 2010.
  1. beenthere
    Thread Starter Retired Moderator
    Apr 20, 2004
    15,815
    283
    One of the things I have just found out about is that the silkscreen text is not tied to the PCB layers. When placing several PCB layouts together as a larger composite PCB, some of those layouts need to rotate to fit better and save space.
    The you discover all the part numbers and labels are still in the original orientation. Some considerable time is needed to get things to look the way you had intended.
    I'll have something to report about the quality of the PCB's in a bit...
  2. maxpower097
    Feb 20, 2009
    795
    388
    Any word? I'm going to want to run a couple proto's soon and was wondering how it turned out.
  3. beenthere
    Apr 20, 2004
    15,815
    283
    Ho, ho. The economy of scale applies, so I want to order something like 10 sets of boards (each large board gets sawn into 15 smaller ones). So I am triple checking foil and component identifications.
    The larger issue is about a workshop in which I might expect to sell 8 - 10 instruments. My USDA researcher has not go the approval to interface with a state university to host the event. So no order until the checks are once again made, and I get the word that my market may exist.
    The issue with the silkscreen layer text was a big time sink, though.
  4. BMorse
    Sep 26, 2009
    2,675
    234
    I have always used ExpressPCB for proto's and production PCB's, I have never had issues with their boards or silkscreen..... for that matter I had never any problems with their PCB's, I even got gerber files from them once for another board just so I could have someone else make them (This company also did the component assembly, that is why I switch to them from ExpressPCB) but for just boards, I have had good experience with them.... as a matter of fact I just spent over $6K with boards that I ordered from them....
    here are some of the boards >>> I had multiple designs made at the same time... ExpressPCB.jpg
  5. beenthere
    Apr 20, 2004
    15,815
    283
    Thanks for the feedback. Those boards look nice.
