Casting resin as potting compound?
Discussion in 'General Electronics Chat' started by rjjenkins, Jul 7, 2014.
  1. rjjenkins
    Apr 16, 2011
    102
    Is there any reason why I shouldn't use casting resin as a potting compound? The curing process is exothermic which would not be too good for some components, but I think that if you're prepared for a slow cure, it should be acceptable.
    The reason for considering it is that it's cheaper, it's less viscous, and I want to encapsulate the PCB into a mould with quite fine detail.
  2. GopherT
    Nov 23, 2012
    6,311
    4,031
    It really depends on the components and the properties of the resin. Dielectric constant, corrosion and thermal expansion and, therefore, mechanical stresses are just a few considerations. If it is for a hobby, then try it. If it is for mission critical aerospace components, that is another story...
    mcgyvr likes this.
  3. MrChips
    Oct 2, 2009
    12,635
    3,454
    Resin will shrink over time. If the volume of resin is not uniform on both sides of a PCB the board will warp as the resin shrinks.
  4. atferrari
    Jan 6, 2004
    2,666
    784
    :eek: Could you elaborate a little? Why is that?
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    I have used ordinary body filler (fibreglass resin with filler) with success and no visible downside?
    Depends on the application.
    Max.
    Metalmann likes this.
  6. rjjenkins
    Apr 16, 2011
    102
    That's good to know. Has enough time passed for problems to emerge? (eg cracking, warping, corrosion)?
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Not so far, also when you consider its original main purpose and the extremes it is exposed to, it cannot be too frail..
    Max.
    rjjenkins likes this.
  8. wayneh
    Sep 9, 2010
    12,388
    3,244
    Thermal conductivity is perhaps the biggest reason to use the higher-priced potting compound. Dimensional stability is another. So if you wanted to pot a coil, for instance, that needs to fit a tight clearance and not overheat, then Bondo may not be the best choice.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The higher the percentage of inert filler the less the shrinkage upon curing.
    Polyester resin with no fillers shrinks badly, a couple of percent, which can warp and crack electronics and rip parts from PCBs.
    Epoxies and Polyurethanes generally shrink as a liquid before the gel point is reached, then have little shrinkage after gelling.
    sirch2 and rjjenkins like this.
  10. sirch2
    Jan 21, 2013
    1,008
    351
    Thanks RB, that's good to know
