What's the right approach to determining the step response and source free response of the attached circuit? I've attempted to do KCL (usual 1st order analysis) at v1, v2, and v3, but it looks quite messy.
I assume you're not using laplace transforms yet? Either way this is a fairly simple circuit. Everything is in series. You just need one equation. Yes, you use KCL:What's the right approach to determining the step response and source free response of the attached circuit? I've attempted to do KCL (usual 1st order analysis) at v1, v2, and v3, but it looks quite messy.
You welcome. Glad to have been of help...That was helpful, thanks. I'm a little rusty, but I worked it out with your answer.
Thread starter | Similar threads | Forum | Replies | Date |
M | Cascaded Noise Figure | Wireless & RF Design | 1 | |
R | 4026 cascaded counter | Homework Help | 8 | |
T | Cascaded BJT RF Amplifier | Wireless & RF Design | 4 | |
5µs analog DelayLine @100Hz with cascaded LC-Filters | Analog & Mixed-Signal Design | 16 | ||
S | Purpose of cascaded schmitt trigger in Hall sensor | Analog & Mixed-Signal Design | 7 |
by Aaron Carman
by Jake Hertz
by Aaron Carman
