cascaded filter design
Discussion in 'General Electronics Chat' started by vinodquilon, Jun 16, 2010.
  1. vinodquilon
    Dec 24, 2009
    234
    I have designed one LPF using the cut-off frequency equation 1/2*pi*RC.
    I am planning to implement the designed filter as a cascaded form of three LPFs.
    Then, how can I split-up R & C values into three values each for each section ?
    I know, in a cascaded connection net cut-off frequency would be the product of
    cut-off frequency of each sections.
    So, can I divide net R & C values by 3 to get values of each section ?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have you tried using Elsie?
    http://www.tonnesoftware.com/elsie.html
    The freeware version will design up to a 7-pole filter.
    It's really good for a freeware program. It will save you a lot of time.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, I guess I should have actually read that you are using an RC filter rather than an LC filter. :rolleyes: ;)
    Try simulating your filter in Spice.
  4. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    vinodquilon likes this.
  5. vinodquilon
    Dec 24, 2009
    234
    All documents here you have presented concentrate on active filters, but here I am dealing with a simple passive RC filter only used for blocking carrier frequency at demodulation stage.
  6. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Can you show us the demodulation stage you have upto now?
    If you want to make a passive RC network,
    the RC timings off all parts can be the same,
    but the impedance of the 2nd should be higher as the 1st
    and impedance of the 3rd should be higher as the 2nd.
    This is because the followers are loads to the feeding filters.
    Bertus
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you wish to block a carrier frequency, then I suggest you look at Elsie. Well-designed and tuned LC filters will have far better rejection and lower losses than RC filters.
  8. vinodquilon
    Dec 24, 2009
    234
    Here is my Pulse Amplitude Modulation (PAM) application....
  9. Ghar
    Mar 8, 2010
    655
    73
