Cascaded Boost converter for high step up ratio?
Discussion in 'The Projects Forum' started by Hero11, Feb 23, 2014.
  1. Hero11
    Feb 23, 2014
    Hi everybody
    I need to build a Boost circuit to drive some LEDs. I need a high output voltage as compared to the input voltage, but I read it is not practical to design a boost converter with a Vo/Vin ratio greater than 6, while I need a ratio close to 10. Some books say to design in DCM if this is the case. To stay in CCM and obtain the high voltage output, is it realistic to cascade two boost converters? If so, are there controllers that would control both switches or would I need two separate controllers?
    Thanks in advance for any advice.
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    You might try specifying:
    VIn
    VOUT
    I load
    and I can recommend a ps design.
  3. crutschow
    Mar 14, 2008
    13,475
    3,361
    You might consider a fly-back switching converter. They use a transformer to generate a voltage increase as high as you need as determined by the turns-ratio.
  4. Hero11
    Feb 23, 2014
    Is this design preferred for high Vo/Vin ratios? Also, what is the reason a regular boost can't handle the high ratio, is it because it would require a very large duty cycle?
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    Yes and Yes.
