cascaded 4017s
Discussion in 'The Projects Forum' started by sheldons, Nov 30, 2011.
  1. sheldons
    Oct 26, 2011
    616
    101
    been playing with some 4017s.....
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    A 9,999 second egg timer?
    No values of resistor or cap on NAND based oscillator.
    No reset button, though. You always need a reset button. People have a sort of fundamental need to have a reset button available, even if they never use it.
  3. wayneh
    Sep 9, 2010
    12,361
    3,220
    That's nice. But if you intended to post this for posterity, you should submit it to the Completed Projects area. Be sure to read the rules there; your post as-is wouldn't be accepted.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    R2 is too low of a value to ensure that the output of the clock NAND can rise high enough to trip it's own Schmitt trigger input. R2 should be increased to at least 3.9k.
    Place a 10k resistor between the RES line and the output of the lowest NAND gate's output. That way you can add a N.O. pushbutton switch that momentarily connects the RES inputs to +12v.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
  6. sheldons
    Oct 26, 2011
    616
    101
    yes actually checking over the schematic r2 should be marked as 10k,some one has eaten the "0"....as far as the reset goes the customer who im building this for has given me how he wants it designed with the reset as is,but it is very easy to change things around and add an external reset if needed.This is a controller for flashing lights,one of 10.Already have a driver designed for the lighting side
