Cascade amplifiers and gains
Discussion in 'Homework Help' started by catch3624, Oct 7, 2009.
  1. catch3624
    Oct 7, 2009
    Hello people...These problems been troubling me now for days...I need to find out if a signal has passed through three cascaded amplifiers, each with a 4 dB gain. What is the total gain? And how much was the signal amplified?
    Also a signal has a wavelength of 1 Micrometer in air. How far can the front of the wave travel during 1000 periods? Can anyone please help me or give me advice as to where to locate this information.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Each amplifier adds a gain of 4dB. Look on a graph to see how much is a gain of 4db times the quantity of amplifiers. Or calculate it.
    What is the speed of sound? Then calculate how far the sound goes in 1 micrometer times 1000.
  3. catch3624
    Oct 7, 2009
    Do you mean that I could add up each 4dB gain which would total 12dB or is there a formula that I must use? And the speed of sound is 344 m/s but a micrometer is = to 1 x 10^-6. How would/should I calculate this then? And by the way, Thanks for the reply.
  4. JDT
    Feb 12, 2009
    658
    85
    12dB ( = 4dB + 4dB + 4dB)
    12dB ( = 4x)
    1mm
    The speed of sound in air is not important as you have already said that 1 wavelength = 1um. So, in 1 period of the signal it has travelled 1um. We don't know the period but 1000 periods will be 1000 times longer so will travel 1000 times further.
  5. catch3624
    Oct 7, 2009
    The response have been great. Now I can combine it with what I have already learnt and done, I will be able to come to the best conclusion. Thank you.
