This time I may have bitten off more than I can chew. I was "volunteered" to do an N scale (railroad model) working carnival.
I will be running 3 to 4 12VAC motors and roughly 50 - 100 3VDC LEDs. My plan is to use a wall wart to come into the base and power the motors. I would like to do a branch circuit (using the 12VAC input) which steps down the input to 3VDC to power the LEDs. What to use for this step down?
Or would I better off bringing the house current into the base and then using 2 separate transformers/adaptors to accomplish this? Seems awfully cumbersome.
I can solder and I have used resistors which I researched and decided that was what was needed for another project. I understand basic electric and have wired large dollhouses. As far as you guys are concerned, however, I am a babe in the woods.
After Ive (you) have solved my input problems, Ill probably be back to configure the LED runs.
Thank you so much.
Whequeen
Thank you so much.
Whequeen
