That easy, eh? I may have to try that!I have made a couple of "molds" from parts downloaded from thingiverse, I am not sure if you are familiar with OpenScad, but with openscad you can import the stl file, create a cube around the imported part and use the difference() function to subtract the "part" from the block, which will give you a hollow cube with the part shape in it.
