Hi, I'm a complete noob when it comes to electronics, so decided to search the web for an answer, hence my thread on this forum.
I've recently acquired a caravan which needs a bit work doing to it, & while working on it I've found out that the battery charger doesn't work. A few enquirers advised drilling the pop rivets out of the casing to check the fuse inside, which is OK, but I've noticed a resistor has burnt out. (see photos)
First photo is of the circuit board itself, second a close up of the resistor.
The resistor has R17 marked underneath.
I feel confident in replacing a resistor, problem is I haven't a clue where to get one the same.
Could some member advise me/point me in the right direction, or should I just take it to a computer/television shop.?
Thanks,
SS.
Thanks,
SS.
