Car speaker from an MP3 player
Discussion in 'General Electronics Chat' started by Aurbo, Jun 17, 2005.
  1. Aurbo
    May 6, 2005
    9
    I have a set of Sony XS-695S car speakers I'd like to use in my garage while tinkering with this electronic stuff. I have a portable walkman and an mp3 player that I'd have my music stored on.
    Any suggestions on how to power these puppies using my Mp3 player or walkman?
    Speaker;
    nominal 20Watt (max 50W)
    Impedance 4 Ohm
    The label on the spear also says "Power Handling"
    Strontium Magnet type
    Cheers
    Steve
  2. David Bridgen
    Feb 10, 2005
    278
    You need an amplifier between the player and the 'speakers.
  3. Steel
    Member
    Oct 27, 2004
    25
    You will need an amplifier.
    Also, with that Amplifier, you will want to verify the load that it is looking for. Most Amplifiers provide power for an 8ohm load. Your speakers are 4ohm. You will have to wire them in series to prevent blowing your amp.
  4. kensplace
    Jun 25, 2005
    7
    Often wondered about this, could you not put a 4 ohm resistor in line with the speaker to get the load up to 8 ohms, or would this cause some problem or other?
