Car Ramps anyone?
Discussion in 'Off-Topic' started by MaxHeadRoom, Sep 25, 2016.
  1. MaxHeadRoom
    Thread Starter Expert
    Jul 18, 2013
    10,827
    2,495
    Any DIY mechanics?
    For Sale Craigs List.
  2. #12
    Nov 30, 2010
    16,663
    7,306
    He did a few things right, like a 2x4 softener between the concrete blocks and the steel stands, but the blocks are turned soft side up and the 2x4 on the right isn't long enough.
    That's a, "bet your life" scenario by a true, shade tree mechanic.:D
    You can probably wait a while and get the ramps for free from his widow.:(
  3. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I believe the ad was posted by his next of kin!:p
    Max.
    wayneh and #12 like this.
  4. cmartinez
    Jan 17, 2007
    3,696
    2,748
    Pits are far safer than any ramp ... but they're also uncomfortable, dirtier and harder to clean ... I honestly don't know which I'd prefer
  5. GopherT
    Nov 23, 2012
    6,300
    4,020
    My preference is to hand the keys to the Nissan Service manager and say, fix it. I know that may sound elitist but I'm done with that - I haven't crawled under a car since I was 40. I'll still do body work, brakes and struts but nothing that requires me to crawl under a lifted car - exhaust, steering, CV joints, ...
    PS. I also will not on a roof or a ladder more than 10 feet.
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    Could you please repost the craigslist ad in a different format - it is not showing u on iPad.
  7. BR-549
    Sep 22, 2013
    2,164
    415
    At least he put plastic down.
  8. #12
    Nov 30, 2010
    16,663
    7,306
    I thought they were just cheaper.
    No money for jacks? No money for ramps? Dig a hole. It takes all day, but it doesn't need money.:D
    cmartinez likes this.
  9. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    What format works?
    Max.
  10. GopherT
    Nov 23, 2012
    6,300
    4,020
    I don't know, I'm just seeing this... (Was there more than the jpg - a text of the craigslist post?) I'm feeling that I am missing something when I see "x IMG" in brackets
  11. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Only the image, it was sent by a friend.
    It shows full size on a PC.
    Max.
  12. GopherT
    Nov 23, 2012
    6,300
    4,020
    Ok, thanks - I can see the jpg.
  13. crutschow
    Mar 14, 2008
    13,471
    3,359
    What's "soft side up"?
  14. GopherT
    Nov 23, 2012
    6,300
    4,020
    The block is stronger if the voids are vertical (giving compression strength on all top surface). When the void is horizontal - as shown - only three walls support the compression and if the user is dumb enough to put the weight of the vehicle on the unsupported section of the block (above a void - "soft" section), then the block can easily be crushed by the vehicle and the vehicle then crushes the ignorant user.
    When these blocks are used to build anything, the voids are vertical.
  15. #12
    Nov 30, 2010
    16,663
    7,306
    Thanks for saving me the time to type that, Gopher.;)
    GopherT likes this.
