yes you are correct about the size but i still need to connect an acc.... i don't need fuses cuz the PS has an internal relay that I have recently tested ... I was just thinking that I could connect the 2 wires to the main power and connect one of the remaining yellow wires to the acc since acc doesn't really use power...If you are just powering the head unit and that's it, then the 2 wires (Probably 18 gauge) should be ok, since the 2 wires combined are probably larger than the power wire of the head unit (most likely 16 gauge). But I would still put an inline fuse on it.
