Just wishing to clear this up, so then let's suppose we have a 50v 1 farad cap to play with.
If i feed 12v into this cap, what happens, the voltage will rise to 12volts, but does it also fill the cap with 1farad's worth of energy? regardless of voltage supplied... eg, 3v@1f 12v@1f or does it work more like a battery, when it reaches 50v only then will it store 1farad's worth of energy?.. take a 12v lead acid battery, if you feed 12v, as soon as it hits 12v, it's not going to store any more energy but supply 14.5volts it will continue to consume until it hits 14.5v (as it gradually cuts off)
so, voltage input = voltage out at whatever it's rated? or will it only store say 1 farad providing 50 volts are fed if it's rated 50v.... 15v cap, 2farads, it could store 2farads but say at only 3volts? or would you need to supply 15volts to get 2 farads stored.....?
