Capacitors on attic fans
Discussion in 'General Electronics Chat' started by hillretreat2, Aug 1, 2010.
  1. hillretreat2
    Aug 1, 2010
    I have two attic fans which do not fuction any more. Each fan has a GE 97F5706 capacitor attached to them. The fans are getting 120v power but don't start. One of the fans was working until I swapped the capacitors to see if that was the problem. Now, neither fan functions. I thought that I might have reversed the polarity of the leads, of the good capacitor. I don't see any indication of plus or minus(power or common), on the capacitor. How can I tell if the leads are correct. The capacitor is 6uf, 370 VAC with a + or - 6% 50/60 Hz. It indicates that it is a DIELEKTROL VI.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    AC motor capacitors do not have polarity.
    Ken
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
  4. hillretreat2
    Aug 1, 2010
    I didn't think so, but like I stated, after I switched capacitors the motor that was running also quit. I pulled the motors and got no continuity through the running windings but the starting windings had continuity, so I guess the motors are dead. I did get over 10 years from them so I guess I should not complain. Thanks for confirming about the capacitors.
  5. hillretreat2
    Aug 1, 2010
