Capacitors in parallel
Discussion in 'Homework Help' started by Gondo, Mar 26, 2007.
  1. Gondo
    Mar 26, 2007
    Having some trouble with this one, hoping that you can help me,
    Two capacitors have the capacities C1 and C2. One of them has the charge Q while the other one is uncharged. Now they are set in parallel.
    a) Show that when equilibrium is reached, each capacitor has a charge that is equal to the original charge multiplied by the ratio of the observed capacitors capacitance and the sum of capacities.
    b) Determine an expression for the energy loss expressed by the given operators. Explain the reason for this energy loss.
    in a)
    So far we've been juggling around with some formulas:
    Q[tot]=Q[1]+Q[2]=(C1+C2)*V
    Q=C*V
    and the fact that V is the same for both capacitors after equilibrium. We do think we need an expression for V[before] though.
    We are not quite sure how to set up expressions for the situation before... We're not sure whether we need to do some energy-considerations or not.
    Any ideas as for how to move on from here would be greatly appreciated.
    Sincerely yours,
    Gondo
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Which part of the problem do you need help with, and what have you done so far toward a solution?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    As thinkmaker3 has stated you need to post up what you have done thus far, it is easier to give advice to your existing work. Please read.
    We can help you with the necessary equations but need to know where you are currently at. I would start by considering the parallel capacitors as a voltage source (the charge capacitor) in series with the uncharged capacitor, and the equation C = Q/V. Also refer to this post. Think qualitatively about what is happening when you bring the two capacitors together - there is a charge migration from C1 to C2.
    Dave
  4. Gondo
    Mar 26, 2007
    Post have now been updated with our thought on the matter so far... Hope that helped, thanks...
  5. kender
    Jan 17, 2007
    263
    Q[tot] = Q[1] + Q[2]
    Q[1] / C[1] = Q[2] / C[2]
    2 simultaneous equations with 2 unknowns. this can be solved for Q[1] and Q[2]
  6. Gondo
    Mar 26, 2007
    that's not really the problem... I think. hehe...
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Formula for energy of a charged capacitor:
    U = 0.5*C*V^2 = 0.5*Q*V^2 = 0.5*(Q^2)/C
    Prior to being put in parallel:
    1) one capacitor has charge Q and the other has charge = 0.
    2) The capacitor with charge Q has V=Q/C, and the capacitor with charge = 0 has V = 0
    After being put in parallel and achieving equilibrium:
    1) Q[tot]=Q[1]+Q[2]=(C1+C2)*V as previously noted, therefore
    2) V = Q[tot]/(C1+C2)
